Rockford Fosgate T1 Box Help
  • 5
Ok so a ported sub box would give me the best results if i make it bigger to the subs specs?
It's not always "to the sub's specs" that is the best way to go. The better idea is figure out the space you have to work with, and then figure out the best overall design for enclosure volume, port area, and tuning along with sub and port placement to ensure you get the correct response you are looking for.
Ok thank you everyone for your help. Now i just have to try and figure out what size box would work best for my car. Thanks again
The best sounding results that I have gotten for both t1s and t2s from the 10s to the 15s all came off the Rockford site under the box wizard section I Believe.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
Brandon9
Brandon9
michigan
goingdef
    May 22, 2024
    May 22, 2024
