SOLD Rockford Fosgate 4ch Monster; 600w x 4 @ 1ohm! $500 shipped!
mavster
New York, NY
This Amplifier speaks for itself, it is the last USA Made Rockford Fosgate series. When Rockford moved all amp production overseas they decided to go out with a bang. This is a factory refurbed that I bought and never used, why? Because I couldn't fit it anywhere decent! Its over 33" tall!
I am also throwing in free shipping for the continental USA via Fedex Ground.
Output Power at 14.4V (CEA-2006):
4 x 125W @ 4 ohms
4 x 250W @ 2 ohms
4 x 375W @ 1 ohm
2 x 500W @ 4 ohms bridged
2 x 750W @ 2 ohms bridged
Fuse: 250A ANL
Dimensions: 33" x 13" (84cm x 33cm)
Weight: 36 Lbs. (16.3 Kg.)
According to Rockford tests the amp does (14.4V and 1% THD+N):
4 x 350W @ 4 ohms
4 x 500W @ 2 ohms
4 x 650W @ 1 ohm
2 x 1000W @ 4 ohms bridged
2 x 1300W @ 2 ohms bridged
Thanks!
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
mavster
mavster
New York, NY
kmanian
    May 12, 2024
Brendon Jenness
    May 11, 2024
