Rockford Component speaker help
If they will be seeing a true 75w or more, night and day difference. If you are running them off the deck or a smaller amp, the T1s are a bit more efficient and will be louder.
On more power the T2s are much more full sounding. T3s a huge step up from that. Haven't had the privilege of hearing the T5s but I'm not paying $1600/set to find out either.
EDIT: I'm soon to put T1s on my 300.4 because it's not enough power to warrant the T2 or T3s.
In my big build I'm doing a 900.4 bridged per T3 set.
so your saying if you amp the t2 there will be a night and day difference between the t1 amped and the t2 amped
If it's a decent size amp yes. If they are both seeing 50w you would still probably be better doing a T1. If you use some of the larger multi-channel amps out there the T2 amped will sound loads better than the T1 amped.
Ok thank you the amp i have right now is about 90 rms x 4 so im thinking the t2 would be a better choice
You could do well w/ T2s.Unless you want to get rid of that T400-4 //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
Yeah i plan on keeping that amp so you think the t2 will sound better on that amp?
Brandon9
Brandon9
michigan
calebkhill
