Rockford Component speaker help
  • 4
I'm sure there is. Cant say for sure tho. I installed the t1 6x9 coaxil, ran off HU power and sounds solid. Hope that helps a lil
If they will be seeing a true 75w or more, night and day difference. If you are running them off the deck or a smaller amp, the T1s are a bit more efficient and will be louder.
On more power the T2s are much more full sounding. T3s a huge step up from that. Haven't had the privilege of hearing the T5s but I'm not paying $1600/set to find out either.
EDIT: I'm soon to put T1s on my 300.4 because it's not enough power to warrant the T2 or T3s.
In my big build I'm doing a 900.4 bridged per T3 set.
so your saying if you amp the t2 there will be a night and day difference between the t1 amped and the t2 amped
If it's a decent size amp yes. If they are both seeing 50w you would still probably be better doing a T1. If you use some of the larger multi-channel amps out there the T2 amped will sound loads better than the T1 amped.
Ok thank you the amp i have right now is about 90 rms x 4 so im thinking the t2 would be a better choice
Rockford t400-4 the birth sheet said 87 x4 i think
You could do well w/ T2s.
Unless you want to get rid of that T400-4 //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
You could do well w/ T2s.Unless you want to get rid of that T400-4 //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
Yeah i plan on keeping that amp so you think the t2 will sound better on that amp?
776
The surprise wasn’t that they didn’t offer one…it’s how much engineering went into making it easily replaceable, and then not offering one. Maybe...
Thanks ya. Just pulled the trigger on the 1500BDCP because of the constant power that RF developed to help with the ohm rise.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
Brandon9
Brandon9
michigan
calebkhill
    May 23, 2024
SPLBassJunkie
    May 21, 2024
