rim help?
One way is to use the rim sizing chart available on several websites.
Another way (for me) is knowing that there are many, many cars that use that same bolt pattern. Toyotas, Hondas, some 4-lug Fords, many Saturns, etc.
The car that I drive, a 1995 Geo Prizm, has that same bolt pattern. My OEM wheels were 14s but i have 17s on it now.
According to the wheel sizing chart on http://www.DiscountTireDirect.com your car can fit up to 20s....but I would imagine some sort of body lift would have to be made for them not to rub.
If you go with 17s, which I know for a fact will fit without rubbing without needing any other mods, the tire size you are going to want to use is the same as mine (to keep your speedometer reading and gear ratio intact as stock) 205/40HR17
dan69372
dan69372
jackson, Ms
Prowler573
