Right side speakers break up
Need a little advice. I recently installed a pioneer avh291bt in my 2004 Mitsubishi. I also installed 2 Sony 6.5 in the front and 2 Kenwood in the rear. The wire harness was all soldered and I used heat shrink tubing on them. I got the schematics for the speakers and cap crimped the door speakers. The left side speakers sound great however; the right side are not good. When volume is under 15 they are clear but when you raise the volume or bass levels the right side sound like the speakers are blown. I have bought another set of speakers and they do the same. I bought a new harness and resoldered all the connections and still the same. I also brought the radio to best buy for them to test it and they said all was good. The only thing is I had to extend the ground wire. Could that cause the issue with only the right side? I have also put the factory unit back in and did not have the problem. Any suggestions would be great.
without being there it is hard to say. I'm thinking it a bad connection or a issue with the head unit. switch the left a right speaker channels to there opposing channels and see if it does it in the other side.
Congratulations toiletpaper....you finally said something smart.
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
Hello, I already posted in general but wanted to also post in here. I recently installed a set of used JL audio shallow depth 12W 1v3-4 inside an...
Makes sense. You may be right on the gain; 2 subs on 300 watts seems anemic.
46
5K
Jak900r
Jak900r
Port saint Lucie, fl
Boomin_tahoe
    May 24, 2024
    May 23, 2024
