Ridiculous question
ive seen countless threads by op about him piecing scavaging and going the cheap route . The box is the more important part of your system stop trying to cheap on it save up a little cash and have a box professionally made once you hear one youll never go back
this wasn't going to be a permanent solution, i just wanted to see if it was possible... i like to experiment
You can try and take which ever enclosure is not built out of particle board(I remember one of them was) and try and work with it.
In most cases with such a simple enclosure it is faster and not to much more to get an enclosure for the new subs.
If your a dead set on trying, just try and take it apart and see what happens. The real issue I see is that those two enclosures are pretty small in net volume and they would need to be enlarged.
It all depends on your ingenuity and your wood working skills, OP. Anything is possible, if you have the right size pieces of wood and you can figure out how to make it fit together, do it to it!
post pics if/when you try.
But, obviously it will not be optimal and building/buying a properly built enclosure is the ideal way to go.
Good luck
Good luck
Want to see pics of FrankenBox as well...
BoomBoxStereo
@woofergram
BoomBoxStereo
Long Island, NY
West
