RF Punch Z or HX2?
B2000
I can get 2 punch Z 12's in a sealed enclosure for 125. or i can get 1 punch hx2 not the power hx2 for 145? which one would you go with. I have an svt focus and i know that it wont take much to get the bump. i wnat asub that hits hard and low, and these are my two choices.
which one?
well, i do not have the money to power the hx2, so i went on ahead and bid on the z's, also since this is my first system, i figured that it should be something that i can thrash on. so when it does blow, im not heartbroken or anything.
Originally posted by B2000 well, i do not have the money to power the hx2, so i went on ahead and bid on the z's, also since this is my first system, i figured that it should be something that i can thrash on. so when it does blow, im not heartbroken or anything.
How much power do you have to work with? Ever considered going with a single sub instead of two?
I was going to ask the same thing. If you push the z's anywhere near their rated RMS. You will have enough power for the HX2. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I have been using a single hx2 12" for quite a while. And I'm quite pleased with it.
Zs? Oh man, I love Fosgate to death, but what were they thinking when they made that thing.
Why dont you get an HE? I think you can buy them for like $60 bucks on the net. Thats what I am running though thats not what I paid for them.
How much power do you have?
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
Class A/B, right? If I recall, these little 2x30 watt jems could best several hundred watts, mono. One of RF's endearing qualities on most of...
739
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
919
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
Once you get the tools and basics down it's not too bad. The turn table is a must imo.
988
B2000
B2000
Suwanee, Georgia
mrmagoo_83
    May 12, 2024
Brendon Jenness
    May 11, 2024
