RF punch 301s
  • 4
Dtrom
MAF
4,113
Rf punch 301s
10/10 working 8/10 cosmetic.
$75 shipped maybe trade need deadener but offer up
On me USPS
Thank you do you know where I could get a 500 watt rms amp for under 80$ it's for a audiotechnix 15
Yes I do but posting in someones for sale thread is not the way to do it. Post in WANTING TO BUY section and post what speaker youre trying to power and what your final ohm load will be. Follow the same rules here or you'll never get what you want from this site
75 watts RMS x 2 at 4 ohms
150 watts RMS x 2 at 2 ohms
300 watts RMS x 1 bridged output at 4 ohms
stereo or bridged mono output
4-ohm stable in bridged mode
Tri-way capable (Tri-Way crossover required)
requires a 10-gauge wiring kit with a 30-amp fuse — wiring and hardware not included with amplifier
variable high- and low-pass crossovers (50-250 Hz at 12 dB/octave)
MOSFET power supply and output devices
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD — advanced protection circuitry for "intelligent" shutdown protection
variable Punch Bass (0-18 dB boost at 45 Hz)
speaker- and preamp-level inputs
Just in case anyone else doesnt have google.
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
Class A/B, right? If I recall, these little 2x30 watt jems could best several hundred watts, mono. One of RF's endearing qualities on most of...
856
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
Dtrom
MAF
Dtrom
Dtrom
    May 31, 2024
    May 24, 2024
