RF amps???????????
yuppers try a bd500 or bd 1000 instead of the 800 might be easier on your car=)//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
in rockford the 600.4 is fine but look at the bd 500 or the bd 1000 they are rockford also...just a thought the 800 is good but ***** mo juice .............
Rockford makes darn good amps and for your setup, I would recomend the 800.2. You might even want to go with the Rockford 1000 watt amp.
yea i got a bd1000.1 t0o, but i think got a dud cuz its only 1064 watts, thought i would get more, since they say they are inderrated by alot, not much here
Thats odd to see a RF amp like that only 64 watts over. I must say that this is a first. Usually the bare minimum I see is 125watts over. I have 2 500a2 and one birth sheet says 782!!(Oh yeah) and the other is 714 which isent bad by any means. But a bd1000 you should be getting like 1150+. Bring it back and ask to look at his other amps so you can choose you birth sheet accordingly!!!!!
158
417
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
Lmyb's
Lmyb's
houston,TX
audiolife
    May 18, 2024
    May 16, 2024
