review my build with me. new guy :)
95batmobile
13
md
Ok so my build is in a 92 bronco with a 5.0.
Amp: a brutus(or watever that brand is). On ebay thats 2400 rms
SUbs: 2 15in kickers with 1000rms.
Wiring. Some 0 guage kit fron ebay thats a hundred bucks
Box: an ebay ported box.
Battery: yellow top optima
Altrrnator is a 200-220a
And i.think thats it. Any advice or inputwould be greatly Appreciated
The Hifonics amp shold be fine, but i don't think you will see the full 2400 but it should be close. Are the subs d2 or d4?
What wiring? You can get enough Knu or Audio Technix for that price. Battery and Alt shold be fine.
Throw a designer $20 and have then design you a proper box and build it yourself. It will out perform and prefab you can buy and probably be cheaper.
box and wire, def get a box at built/designed and build it yourself. just make sure you get good wire, not some 4 ga labeled as 0 gauge.
What Kicker subs? I would ditch the enclosure as well and get one designed for you to build or have one custom built.
Be sure you are using good wiring and have it wired properly.
Other then that..meh, looks ok I suppose.
Amp: a brutus(or watever that brand is). On ebay thats 2400 rms As has already been noted, don't count on ever actually seeing 2400 watts out of it, but Hifonics is okay
SUbs: 2 15in kickers with 1000rms. Regardless of what Kickers these are, they are meh
Wiring. Some 0 guage kit fron ebay thats a hundred bucks Kits... meh
Box: an ebay ported box. Nope!
Battery: yellow top optima Good batts, depending on whether or not they are sufficient for actual needs. Big Three first and foremost
Altrrnator is a 200-220a Nice
Read and research, and ask moar questions, before you drop a load of $$ , especially on eBay shit
... why cant i put up urls....................
---------- Post added at 01:05 PM ---------- Previous post was at 01:04 PM ----------
but thanks for all the responses guys, im am trying to put up exactly what im buying.. but its not letting me
and ill build my own box. also ill prob put up a WTB thread incase anyone might have something i need for cheaper
what head unit are you using? tsunami wire is ok to use. those subs and that amp should match up well wired to 1ohm but if your still using your factory highs off the oem deck that bass is gonna dround them out terribly also look into doing the big three (research it) good luck with the build
for ur wiring kit that you posted. i noticed there is no speaker wire? i do have 16 guage laying around, would that be fine to use or do i need big speaker wire for the subs
95batmobile
95batmobile
md
relaxin612
