replacing bookshelf speakers.
toolfan89
official ca.com shemale
ok so as the title says i wanna replace my bookshelf speakaz. its a philips c577 about 330 watt max and 6 ohm the only thing i could find to replace them is some pioneers. http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=290-155 the ones in the link are 15s and 100wrms an 140wmax at 6 ohms. and should be perfect to replace my litte 61/2s that are the same exact rms. does anybody else have a suggestion.
Uhhh, it ain't gonna work. You want to replace 6.5" bookshelf speakers with 15s? //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
how is it not gonna work? unless your thinkin that im trying to put the 15s in the old boxes then no. and the 61/2s an 15s have the exact same power ratin an everything.
i know i have to have the mid and tweeter i already have that part figured out. i was just looking for some 6 ohm woofers to go with it. an i know its not gonna be considered a bookshelf system. the system as itself right now isnt even really a bookshelf system. thats just how they classified it.
You need a midrange and tweeter to go with that if you want to actually get music out of it. And if you build a 15" 3-way it would hardly be considered a bookshelf speaker.
The Altec Santana/Valencia line basically was a 15" two-way bookshelf, needed one hell of a bookshelf though //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
You mean this guy? Is there anything special about the cone?
Nothing really, they're good up to 800Hz or so...
They sound a lot better when you disconnect those crappy cone tweets and run Altec horns for the top end //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
toolfan89
toolfan89
your moms cooter
JimJ
NorthFramingham
    Jun 30, 2026
