removing stock radio and installed new head unit...no sound?
  • 4
I'll just assume you have an LX since you supplied approximately 'zero' useful details on your system and car.
If you do have an LX, make sure all the connections are correct using this diagram:
Sorry kinda new to all of this. Its an EX . Everywhere I go and look up they say the harness is 70-2003 but it won't play sound. I have my k-wood in my jeep and it was no problem at all. This one is a dual (maybe that's the issue haha) idk I'm going crazy
Alot of guys on here don't care for your problems. I have one forum with 900 views and one answer Lol.
It's a dual head unit. Very dodgy. Assuming it turns on, make shure its tuned to a known station in your area that you know you can recieve, or play a CD (Some duals don't have it)
Get a multimeter, or even a small light bulb. Ground it to the chassis, put your meter to volts AC or your lightbulb to "light" //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif and your radio to 50 percent volume, and poke at all your audio out channels on the dual radio on the positive side. If the meter or bulb gives a reading or flash, your putting out audio. (Probably best to have a CD in and playing assuming your dual can play them) if you have no signal, check your fuses and unplug the radio for 3 minutes. Turn it on. If this still doesn't help, try getting a 12 Volt signal feom your harness and VERY quickly tapping it on your speaker wires. Make shure its the postive side of the speaker, not the ground. If it makes a popping sound your good. MAKE SHURE YOU DO IT QUICKLY! Don't hold it on there just a quick Tap. Then, double check your wiring. If all fails, burn the dual with carb cleaner and spend 90 bucks on a JVC radio, or alpine. You will not regret it I promise.
477
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
291
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
502
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
As for a coned speakers (woof, midbass, mid) driver polarity, a common household D cell battery works great. Connect the batter to wires, touch...
753
poonjabber
poonjabber
allentown, PAstock
6inarow
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
