remote wires???
perrydog
ok i have a kdc mp628 headunit and i want to run 4 kac 7202's but i need 4 remote wires for that and i know you are not sapose to run more then 2 leads of your headunit....how do i split my 1 remote wire into 4 leads without blowin my headunit? i heard sumthing about a relay or sumthin b4 but i need to know what i need exactly and how much, were and all that? let me know asap please //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
see that confuses me.....sorry im kinda new at runnin more then 2 amps....please stick with me on this...a relay? can i buy one sum were....ya know like a dist block'?
ill send you a diragram with a pic. in a pm //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
alright sweet..... i hope this helps me out i dont know why i ever bought 4 amps.....well besides i got a sweet deal on em
Likely for the same reason I bought the amps that aren't being used for anything but a ghetto-rigged setup in my room or taking up closet shelf space //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
We all understand car audio is more than a bit of an addiction ~ it's okay....
lol yes it is an addiction.....thats the perfect way to explain it to the women...ill tell her its kinda like buyin a purse....ya never can have to many
now will that piece let me run 4 remote wires of the HU cuz ill print that out and take it to emm tomororw lol
No - you don't need to run 4 wires off of the head unit when using a relay.
The relay requires its own source of power and ground. That will use two of the four terminals on the underside of it.
Then one of the two remaining terminals will be where you connect the remote accessory activation output coming off the head unit (the trigger input on the relay)
The final remaining terminal will be what activates your accessories (in this case four amps) after being triggered by your head unit. it will be this terminal where you'll want to attach four wires. (or just one and then attach the remote input on the second amp via a jumper off of the first amp then the third amp via a jumper off of the second etc etc etc)
so ok i think i get it.....on the underside you have the seperate pwoer and ground then a spot of a input and a output....i am goin to put the single remote wire in the input and have a single come off the output then split that wire into 4 wires? or what is this jumper you talk of
ok so i need one 30/40 amp relay....and a terminal strip?...whats that exactly?.....and how do i power this lil relay...i mean ground is self explaitory
perrydog
perrydog
g-ville
perrydog
