How do i check the voice coil of a subwoofer?
which color is positive and negative? and i have 3 options to plug stuff into
unfused/10Amax
V ohm sign mA/200A max fused
COM
Which do I plug the pos and neg into?
No...
And the number you get won't be a single digit number, likely...for example, you may get a DCR reading of 3.2 for a "nominal" 4 ohm VC. Because the actual impedance at any one time depends on the position of the cone.
Also, the number may jump around a bit not too much if it jumps around a lot from 0 to 5M? then there might be a problem somewhere.
Black to COM = Negative
Red to V ohm sign mA/200A max fused = Positive
Also, if it's a Dual Voice Coil sub make sure you are ohming the same coil....
Hayabusa
Audiophile
Hayabusa
Mississippi
Hayabusa
