remote wire q
I will soon be getting an amp for my front stage. I want the amp to turn on when i turn on my HU, the HU is stock, how would i go about wiring the remote wire?
Depends a lot on the car, you may need to use a relay through the fuse box.
get a DMM and find something in the fuse box that puts out twelve volts when the car is started
Not always a good idea //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Helped a fellow member here install an amp and subs, hooked it to a hot wire at the fuse box. Worked fine, but when you turned the car off...the key wouldnt come out of the ignition. Crazy stuff. With a '02 camery you may have the same problem like that. Not sure. Options, Ignition, cigerette liter, relay switch, power antenna.
I have a funny problem like that in my car. The stock cigerette lighter 12volt line is dead for some reason (bought the car like that, thinking the first owner had the dealer cut it for safety). I use that for cigerettes if I can't find my lighter and my PnP Sirius unit, so it NEEDS power. I spliced it into a wire that is in the harness of my emergency flasher button (only thing on the other side of the harness) so that it can have 12v constant, but when I turn on my bright lights, it kills that wire. I still have no friggen clue why that would happen (especially wtf that wire would be used for!)
Dj-torn
Still learning...
Dj-torn
Fairchild, WA
THUNDERBIRD
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
