remote turn on issue with LOC....solutions???
jjoseph8907
Alright so I am using a LOC to run the signal to my amp as I opted to continue to use my factory deck, only one problem - how do I connect the remote turn on to my amp?? I cannot do this through the LOC as far as i know, and I would more than willingly run the line to my OEM deck, but it doesnt support me connecting a remote turn on line to it as far as I know. I read that I could connect the wire to any device which turns on when i turn my key to the ACC position, but I cannot think of any of these that would be easily accessible and that I would be able to connect to. Any solutions to this problem? Is there any way I could splice and connect the wire to the speaker wire which i have spliced and connected with the LOC and seal it with electrical tape? would this work? It doesnt seem like a major problem but i cant figure out a fix....
Thanks in advance for the help
You can get a cheap Haynes or Chilton manual for your vehicle and it contains electrical schematics as well as mechanical step by step repair. Get yourself a test light and find a source of power only when the key is turned on, but ideally you want remote off of the factory deck.
jjoseph8907
jjoseph8907
St. Petersburg, FL
jjoseph8907
