Remote Relay Help??
profoundwill
Looks like I am going to have to run a relay for my remote to my amps, becasue my amps will not stay on and I have tried everything else as far checking grounds and loose connections. The question is what guage wire do I need to run to the relay from the radio remote, can I use the standard 16-18ga remote wire? Does it need to be fused? Thanks
Have a question, if my headunit turns on all my gear and everything seems to be working well do I still need a relay? Can I cause damage without giving it that extra voltage. Mind you that I am running 4 amps, 2 sound processors, a crossover, and a preamp.
I know people recommend using a relay, my question though is what will happen if I DONT use a relay? I dont have a problem with anything shutting off or not turning on.
profoundwill
profoundwill
Birmingham, AL
helotaxi
BP1Fanatic
BP1Fanatic
