Relocate battery for dB drag?
· The primary battery must be located in the same general area as the OEM battery location. (For example, if the OEM battery location is under the hood, the primary battery must be located under the hood as well. Aftermarket battery trays and/or custom fabricated battery brackets may be installed provided no other applicable rules are violated.)
cut and pasted from street max rules
Planning the wall still and in that, I was wondering if it was against the rules (in Street Max 1-2) to relocate the one allowed battery to the trunk? It seems like a much easier thing (and cheaper) to extend the stock wiring to the trunk and use 1/0 from there then it will be to run 4 runs of 1/0 from the front to the back...
http://www.termpro.com/dbdrag/
this will tell you what you need to know
Kenny Pollock
drag it!
Kenny Pollock
Hollywood, Florida Low: Yes
keifersracing
