Relay help!!
L1ttlet
CarAudio.com Regular
165
So after daisy chaining my 2 amps and 2 volt meters off the same remote wire, my 4 channel will shut down when a certain volume is hit.
I now realize that I need to get a relay. I've been researching relays. There are 4pin- 8pin maybe more. What is the point of all the pins. I understand
Pin 85- to ground
Pin 86 - to remote turn on from headunit
(Or u can switch the two with no effect)
Pin 30- to +12volt connection
Pin 87- to accessories desired to run
What is all the extra pins for?????
Do I need to fuse the wire going to each amp from the relay at like 5amps???? If not why?
I want to run my cooling fans off of it and probly leds in future.
So a 12 volt 4pin 80amp should suffice- 2 5amp draw cooling fans
2amps
3 stinger voltmeters
Plus leds.
I'm pretty confused as why I'd want 80 amps going to amps or even 5-amp cooling fans and not fuse the wire- do I fuse between relay and accessory ran?
The last time I bought a relay, I just went to Autozone and bought a aftermarket fog light relay kit. ( I think it was made by Blazer ) 30 amp relay with wire and a fuse holder for less than $10.
Yes fuse your relay.
That doesn't make any sense. The directions say to hook it up to the parking brake. The parking brake is engaged when the car is off. You...
17
6K
80a Alt. is your problem....i have a 2017 spark, no way i would go over 1000rms on stock electrical in that thing....and your cap aint doin...
55
155
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
177
L1ttlet
L1ttlet
L1ttlet
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
