Reconing gone wrong
kalkx
florida
started to recone my sub today took off the old cone and immediately the motor assembly shifted and got magnetized to the side. tried to get it back centered but just did more harm then good. how should i have went about fixing this other than taking a flat head and hammer to it?
youre not going to fix it on your own. It needs to be de-magnetized, re-assembled and re-magnetized...
not anything you did, sounds like the coil/former was holding it together..as in not allowing it to shift and once you pulled the assembly it went..happened to me a few times.
Wtf? I dont have **** to contribute here but its pretty funny!//content.invisioncic.com/y282845/emoticons/offwall.gif.29a91b9b265d47af4b8e33fc5b558d18.gif
i fix them //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
luckily i have another blown that i can use to recone but if i ever decide to fix this one ill let you know
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
5K
The first thing you should do is double-check all of your wiring connections. Usually when people come to me with this issue it's a loose ground...
828
When I was delivering pizza the companies had to raise employees wages and in response they hired twice as many employees and cut everyone's...
14
59
Yeah, I plan to run them in my workshop. I haven't gone through them or anything but they startup and run just fine. I don't see any strange spike...
kalkx
kalkx
florida
kalkx
    May 10, 2024
3toneEYZ
    May 10, 2024
