Yup. Im soo happy I dont have to recone it again or tear it apart. Although, now after playing around with it Im getting really anxious to get it in //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif. Which kind of sucks since I dont have the time to work on the audio part of my car for a while.Thanks! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Good to hear it was only a glue problem.
Most of the glue is worn off at this point. Im guessing theres just some left near the top of the former. Im just not able to get the needed excursion out of the sub with the little power I am using with this small plate amp.Do you think a 40-80hz sweep would get rid of it over night?
Nevar!!! //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gifyou should just buy a new one n sell this one to me for 10 buckz //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Well due to were the glue is at inside the former most of it would more than likely blow right out the pole vent I would think, Im sure some could fall down into the gap though, but hopefully blow out.My question is... what happens to the glue that gets chipped/melted off...? Does it disintegrate...?
One reason I like to use epoxy.. you can lay the glue, put the assembly in place.. then shim and you are still golden for 2-3 min before the glue sets..laying down glue, then dropping it in, then shimming it after the glue is down may be part of the issue. I prefer to shim it tightly using printer paper. It works perfectly on a 3" coil. Once it is shimmed tightly and the spider/surround are about 3/8" above their landings i lay down a nice bead of glue and then press the cone assembly down. That way you know the thing is aligned the moment it contacts the glue and nothing has a chance to get out of alignment.
