Recommended RMS
Hello,
I am looking for a simple audio system, and I have come across a Sony CD/MP3 receiver with 208 Watts max (23.3 RMS X 4; 52 X 4 Max) I found some 5.25 in. Sony Speakers with a Recommended RMS of 45 Watts. I am wondering if this will cause any problems with sound quality or if it will damage any of the equipment if I use this comfiguration. P.S. I am planning on using 3.5 in. speakers in the dash that will use up the other 2 channels.
Thank you very much.
Head units are usually insanely overrated in RMS wattage. It's doubtful you'll see any more than 10-15w coming out of each channel. I mean, look at the fuse on the HU. Probably a single 10-15A fuse. Look at an amp that puts out around 25-30W RMS, chances are it's got a 30A or higher fuse.
Everything Sony makes is also insanely overrated, I had 4 Xplod speakers in my car with 30 watts to each (rated at 50W RMS) and they all blew. I don't think they're safe with 1/2 the recommended wattage.
What's your budget? There's got to be better deals out there...
"sony" and "sound quality" should not be used in the same sentence together unless the words "sucks for" are inbetween them.
You could find some better speakers for the money that will sound ALOT better for the same price range.
No, don't bridge channels on the H/U. Also, H/U's will have high distortion and can be driven into clipping really easy. You will be fine with that equipment, but after purchasing it, if you can save up for a 4 channel amp, that would be ideal, and result in a huge increase in sound quality.
T.J.
brendan_121212
Saudi Arabia
brendan_121212
