recommended amp for my subs
88k5blazer
hey guys im a newbie when it comes to subs and amps so i gotta ask. I am lookin at buying 2 alpine 12" type r subs and dont know whether to go with the SWR-1241d or the 1221d. They both have the exact same specs but one is (2ohm+2ohm) and the other is (4ohm+4ohm). What exactly is the difference and which is better?
They are both basically the same. The difference is the wiring configurations. You said that you wanted to go with 2 12's so if you get the 1221d you will be able to get a final impediance of 2 ohms, or 0.5 ohms.
With the 1241d's you will have the options of 4 ohms or 1 ohm.
If your amp is stable at 1 ohm, or 4 ohms then you will want the 1241's, if it is stable to 0.5 ohms, or 2 ohms then you will want the 1221's
Ya with 2 of the 1221d's you can get 8 ohms as well, but i have yet to see a car amp that makes its power at 8 ohms, not to say that there aren't any, or even lots, but I have never seen one. You can also get 0.5 ohms with the 1221d's as I said earlier
ight thanx guys, that site helps alot noodles.... i think im gonna go with the 1241d and run themwith the rockford fosgate power bd1000 which will give me 1000 watts at 2ohm.... Am i right on this?
88k5blazer
88k5blazer
Texas
BooLeaN
michigan born
    May 14, 2026
michigan born
    May 14, 2026
