RoachForLife
So heres what Im looking at. Either the 2 PGs or the 2 Kickers. Specs below.
Thanks!
Subwoofer
Either JL W6v2 12" or IDQv3 12"
PG X600.1
24dB Linkwitz-Riley subsonic and low pass crossovers
variable thermal feedback controlled fans
Remote Monitoring Display (RMD) port
Low Pass Level control ready (LPL-44)
600W x 1 (4-1 ohm)
Variable input sensitivty
0 - 18dB Bass Boost at 45Hz
Dimensions: 18.25" L x 10.6" W x 2.5" H
RMS Power (4 ohms): 600 watts x 1 chan.
RMS Power (2 ohms): 600 watts x 1 chan.
RMS Power (1 ohm): 600 watts x 1 chan.
Bridged RMS Power: Not Bridgeable
Peak Power Output: 1200 watts approx.
THD @ Rated RMS Power:
Speaker Level Inputs: No
Amp Preamp Outputs: Yes - 1 pair
Built-in Crossover: LP (30 - 300Hz), Subsonic (5 - 55Hz)
Bass Boost: 0 - 18dB(45Hz)
Signal-to-Noise Ratio: >90dB
Fan Cooled: Yes
Fuse Rating: 60A
Warranty: 1 Year
$250
08ZX500.1
RMS Power Range : 500 Watts
Number Of Channels: 1
Low Frequency response: 20 Hz
High Frequency Response: 200 Hz
Built In Crossovers: Yes
Channel Separation: Yes
RMS Power @ 2 Ohm: 500W x 1
Signal-to-Noise Ratio: >95db
Input Sensitivity Low Level: 125mV-5V
Input Sensitivity High Level: 250mV-10V
Selectable Electronic Crossover: Variable HI, LO or OFF (bypass), 50 - 200Hz, 12db/Octave
Bass Boost: Variable 0-18db Bass Boost @ 40Hz
Dimenstions: 12"L x 2-1/8"H x 9-5/8"W
$240
Components
PG RSD 6.5s
PG X200.2
Number of Channels: 2
RMS Power (4 ohms): 200 watts x 2 channels
RMS Power (2 ohms): 200 watts x 2 channels
RMS Power (1 ohm): 200 watts x 2 channels
Bridged RMS Power: 400 watts x 1 channel
THD at Rated RMS Power: 1.0%
Built-in Crossover: High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency: 40 - 400 Hz
Low-Pass Crossover Frequency: 40 - 400 Hz
Subsonic Filter: N/A
Signal-to-Noise Ratio: 100 dB
Bass Boost: 0 - 18 dB
Bass/Gain Remote: Optional (Phoenix Gold LPL-44 required and sold separately)
Fan Cooled: Yes
Fuse Rating: 60A x 1
Dimensions: 14" L x 10.6" W x 2.5" H
$175
08ZX350.4
4-channel car amplifier
60 watts RMS x 4 at 4 ohms (90 watts RMS x 4 at 2 ohms)
175 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
variable high- and low-pass filters (50-200 Hz, 12 dB per octave)
variable bass boost (0-18 dB at 40 Hz)
speaker- and preamp-level inputs
fuse rating: 20A x 2
8-gauge power and ground leads recommended wiring and hardware not included with amplifier
13-1/2"W x 2-5/16"H x 9-5/8"D
2-YEAR EXTENDED WARRANTY
$200
Thanks!
Subwoofer
PG X600.1
600W x 1 (4-1 ohm)
Fan Cooled: Yes
Fuse Rating: 60A
Warranty: 1 Year
$250
08ZX500.1
$240
Components
PG RSD 6.5s
PG X200.2
Fan Cooled: Yes
$175
08ZX350.4
$200
