Recommendation for my Kicker 11VS12L72
RobNyc
I just bought this sub and looking for a good amp recommendation.
Kicker VS12L7 12 Inch 750W Solo Baric L7 Single Subwoofer Box 2 Ohm [11VS12L72]
SKU: 11VS12L72-N
RMS Power Handling (Watts): 750
Peak Power Handling (Watts): 1500
Subwoofer Size: 12 Inch
Basket Material: Cast Aluminum
Cone Material: SoloKon
Frequency Response: 20-100 (Hz)
Hole Cutout Diameter: 11-1/16"
Impedance: Dual 4 Ohm
Mounting Depth: 6-11/16"
Recommended Ported Box Cubic FT: 1.75 - 3.25 (CU. FT)
Recommended Sealed Box Cubic FT: .88 - 2.0 (CU. FT)
Sensitivity (dB): 88.6
Surround Material: Santoprene Rubber
Final Impedance: 2 Ohms
Width: 18-3/4"
Height: 16"
Depth One: 18"
Depth Two: 14-11/16"
I chatted with someone from HalfPriceCarAudio website where this sub was purchased at.
They said this sub is a dual 4 ohm wired = final 2 ohm
"that box has a dual 4 woofer wired down to a 2 ohm load. So you want an amp that is 2 Ohm stable"
So I would require a 1000W RMS @ 2-ohm stable amp correct?
I really don't know much about this and would like to hear a few amps recommendations for daily use and that last.
I would like to look at a few from different price ranges and avoid the cheap stuff that will not last or heat up.
I have a Cadillac STS 2006 V6 w/ Factory Navigation, had a guy do the wiring stuff in the back where the factory amp is located and there the conenctions for the amp are ready. Ground, Remote, and Volt i think it is. Subwoofer is already sitting in my trunk ready for its amp.
Thanks
I've been researching and researching
I came down to these that are in my budget and they come with a remote //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
-Soundstream DTR1.1700D (Amazon expensive) but on another site its on sale for $188
1100 Watts RMS x 1 @ 2 ohms
-Hifonics BRZ1200D (900 Watts RMS @ 2ohm)
-Hifonics BRZ1700D
Audiosavings Amazon store
Same price $179 (Not including my gift certificate)
- Hifonics Hfi1500d
4 ohms: 500 watts x 1 chan. 2 ohms: 1000 watts x 1 chan. 1 ohms: 1500 watts x 1 chan.
- Hifonics Brutus Brz1200
4 ohms: 450 watts x 1 chan 2 ohms: 900 watts x 1 chan. 1 ohm: 1200 watts x 1 chan.
$199
- Us Amps Xt V3 Series Xt4000de
$213
- Hifonics Hfi2000d
4 ohms: 650 watts x 1 chan. 2 ohms: 1300 watts x 1 chan. 1 ohms: 2000 watts x 1 chan.
$230
- Re Audio Xt V3 Series Xt4000de
$249
- Hifonics Brutus Brz1700.1
4 ohms: 600 watts x 1 chan. 2 ohms: 1200 watts x 1 chan. 1 ohm: 1700 watts x 1 chan.
Hope you guys can help me make the right decision because this is it.
RobNyc
RobNyc
New York, NY
RobNyc
