Recommend amp for two sa12’s
Not looking to spend more than 400
Preferably around 300
It’s the dual 4ohm sa12’s
Right now currently have a boss 4000 that is actually 900 watts at 1ohm not the 4000 it’s advertised as.
How much power should I look at giving these two sa12’s to make them really shine?
Wow that looks perfect thanks
sure it's same board as twisted sounds 1.3k.. korean board., it'll be mucchh stronger than any boss ever.. however u really need to do big 3 wires under hood and 0 ga wire (or 2ga or 0ga welding wire) to power that most likely..
You can look into the Soundqubed amps as well if you want some power on a budget. The S1 2250 for $250 (Chinese) and Q1 2200.2 for $398 (Korean) will give you more power after box rise. For running this power definitely do the big 3 and I'd use the biggest AGM you can fit under the hood and go from there.
Lovebass805
Lovebass805
Los Angeles
youdoofus
