recomendation before christmas lol
alright i have an audiobahn aw1200q(700rms) and am looking for a decent class d to push it at a 2 or 1 ohm load....i was looking at the hifonics bx1000d of that merlin one(450rms at 1-ohm). any other recomendations under 200 dollars? oh yeah, sq is a huge factor....thanks fellas..
//content.invisioncic.com/y282845/emoticons/omg.gif.05aa02c3095d6ce9338996654eca0863.gif dude why the **** are these here?
you cant run it at 1 ohm unless you have 2, but you said you have 1 so get an amp for about 600-700 watts @2ohms, oh yeah with an audiobahn you want get a high ampunt of sq, i had some. i love my SX i have now
anything under 200 would be fine, or a lil over....any opinions on hifonics?oh yeah i heard that audiobahn amp was 800 PEAK....
hifonics isnt bad really i heard they are about 20% over rated however from a trusted source..although to put into terms there isnt that big of a diff between 800 and 1000 watts unless you plan on doing db drags that would be a few .1's of a db....
Older hifonics were good, I've had a ton of problems with the newer ones (past '97). If you can find an older one then you'll be ok. As far as Good SQ for under two hundred bucks... good luck on that one. For decent SQ you should expect to spend at least 250-600. Oh and by the way.. Audiobahn does not produce SQ amps. They produce cheap amps that beat away at you with senseless distorted power. Anyone who is deep into car audio will tell you this.
Try to find some prices on the following manufacturers of amps. You should be pleasently surprised at what you find. JL Audio, Kicker, Lanzar OPTi's, Phoenix Gold, Fockford Fosgate (older amps) and Power Acoustik. These will all be competively priced and will offer good, quality manufactured products.
strungout951
strungout951
valley of apples, ca
strungout951
