reccomendation for set up '03 Yukon
  • 4
cmuwallif
Hey need help finding the right subs for this box. I'll be runing a audiopipe 1500 on em'. BTW I'm kind of ballin' on a budget so pls. consider that. Thanks
Item Description:
MEASUREMENTS
LENGTH 46"
BOTTOM DEPTH 10 1/2"
TOP DEPTH 8"
HEIGHT 21 1/4"
AIRSPACE: 1.49 CU.FT. PER CHAMBER.
MOUNTING DEPTH: 9" .
CONSTRUCTION IS INDUSTRIAL MDF 5/8" BOARD.
Did you buy that box ? because 3/4" MDF is kinda the standard everyone lives by around here. Also, you're kinda doing it backwards. Why not find some subs you like, and get a box that suits them. Just sayin..... Just look at quality names for subs that work well in 1.5 cu ft sealed. Stay away from Pyle, Pyramid, Sony, Lanzar (except OPTI), BOSS, Sound Storm, Planet Audio, etc.
Also throw out a dollar amount...then people will suggest up a storm.
Id also take a look at Ground Zero to see if you may find an amplifier that meets your needs.. Maybe even Sound Digital...
18
Only problem with the old model I series is they recommend a much bigger box than the current I series. I actually have a pair bnib deciding what...
23
205
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
687
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
767
cmuwallif
cmuwallif
IndY, IN
THATpurpleKUSH
    May 23, 2024
    May 22, 2024
