rear speaker problems
JohnMan
My name is John, and i own a chrysler 300m special 2003. The rear stock speakers were starting to go out so i purchased new ones. Now, the left rear speaker doesnt make a sound and the right will play some sound but once the volume goes above 3 notches the sounds turns to static/buzzing. I double checked the connection between wires and everything was good. Even switched the speakers around and still got the same result.
I have 2 subs in the trunk that run off of the rear speakers as well. The power wire runs through a cap straight to the amp. The amp works but the amp doesnot. the speaker wires for the amp are clamped onto the rear speaker wires.
Can anyone help me?
This problem happens when you are using a VIA motherboard with the Apollo VP3(VT82C597) or Apollo MVP3(VT82C598) system controller chipset, it causes repeated buffer during a wave playback on ...
___________________
VLC Player
JohnMan
JohnMan
Lincoln, Il
gehlmauer
