ok im considering adding a couple rear speakers - i know rear fill is frowned upon on these boards but because of my less than ideal stock locations.. it is becoming a series consideration...
my options are either the rear shelf or the rear doors.. i was considering adding a set of deep playing mids. (well as deep as i can play in a door) say for example at best: 60-400hz... i figure putting them in the rear shelf will be kinda pointlesss and wont really add much because of the subs and phasing/timing... if i cross them at around 220-400hz and put em in the door (hopefully try to fit an 8 in there) .. it shouldnt really affect the different tone speakers tend to have.. but im not sure "how much" this will add.. and if i will have desireable results.. i dont wanna pull the stage to the back.. but i feel like my setup (which sounds good) is in a way lacking presence, depth, and maybe help the subs blenda little better..
but before i spend the money and cut up my doors - if anyone has ever expertimented orhas a similar setup- i would appreciate hearing your results... and if crossing them around 220-400 seems to high or low..? or if this just seems like a bad idea in general lol
