Rear door speakers arent working at all.
Jrob827
So I drive a 2002 dodge dakota quad cab, with a pioneer MVH-X360BT stereo, I decided to replace all four stock speakers in my doors because the were blown up front and not working at all in the back. I installed JBL GX628 speakers all around. I made sure that they would work and that I had enough power for them to work. After installing them, the front two sounded amazing and worked perfectly, but I'm still not getting any sound at all from the rear two speakers, any ideas?
Hmm, they’re two ohm drivers so they should be amplified externally (not through the deck) As a headunit for 4ohms. Maybe two pairs of them was just too much for your headunit internal amplifier. Disconnect the fronts and see if the rears will play by themselves. May have to get an amp now if your damaged your hu internal amp.
Alright I'll check that thanks.
2002 Dakota not likely separate factory amp. The pioneer hu will probably still work with an aftermarket amp. Get a gmd 8704 amp and you’ll be stoked.
Alright, I just tried disconnecting the front speakers and still didnt have anything coming out of the back. Any other ideas?
It's subjective, but I prefer fronts only. As loud as most of our systems are, the rear passengers can hear the fronts just fine. Imagining even...
117
627
I’ve tried it in 3 different vehicles and multiple locations. Rear deck is best for me. Unless it’s a midbass I don’t want anything in the rear...
10
784
Jrob827
Jrob827
Colorado
BCotrell
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
