Rear battery not charging!!!
i'm officially lost in teh sauce...
one more time...
where is loop? i know he can untangle this mess!! lawlz
when i just get the voltage of the front battery, it reads fine (12.5ish volts). The back battery lasts about 5 days of daily driving then goes dead. When I measure the back battery WHILE STILL CONNECTED TO THE FRONT, it reads
Front batt is always gonna read 12v+ or should. Turn the car over and check voltage. Front and back. Is voltage reaching the back? Is back batt connected to front batt? Is it grounded well?
I was going to say a lot of bad battery installs are from a bad ground. If its a unibody car that "sub frame" might not be what its all cracked up to be.
It is the fuse or a bad connection. If you have checked both of those out completely, the battery is dead and needs replaced.
one more time...
LOL! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I already posted above the answer that should have ended the thread. It had to be one of the following: //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
1) Bad connection somewhere
2) Blown fuse
3) Bad battery
There are no other issues that I can think of. It has to be one of these 3 things. If you are going to assume that you have one of these covered without actually checking it, then I am not going to be able to help. You cannot assume that any of these are not the reason. You must test to see if they are the problem. If you don't want to check each of these, good luck, you are on your own.
kodak314
*****es love it low
kodak314
Orlando, FL
alvitae
