First off, anything and everything, including wire as big as your head, to some extent does add resistance. That said, a good ANL fuse will add an immeasurable amount of resistance to that connection.If you have a ho alt., does a inline fuse restrict current flow?
what size would that be?? pic?First off, anything and everything, including wire as big as your head, to some extent does add resistance. That said, a good ANL fuse will add an immeasurable amount of resistance to that connection.
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh:what size would that be?? pic?
but a fuse doesnt blow with high voltage. it blows on amperage //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gifIt will but as loopkiller said it will be almost unmeasurable. I always say fuse an alt b/c if the voltage regulator does fry it can screw every thing electrical in your car.
WRONG!but a fuse doesnt blow with high voltage. it blows on amperage //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
what if it's high voltage, low amperage though?WRONG!
Fuses are rated at a certain voltage for a certain amperage.
They basically blow at a wattage //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif, but in all reality they blow at a certain temperature that is reached from a certain amount of power passing through it, which is as we all know a function of both current and voltage
It blows at temp, caused by power, so if you have a voltage spike with a amperage valley then it wont blow, but........ that is soemthing that would very rarely happenwhat if it's high voltage, low amperage though?
anyway i was just fckin w/ dude //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
my bad im hyped up on dayquil right now and not thinkin straitbut a fuse doesnt blow with high voltage. it blows on amperage //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
edit: gotcha //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Have some whiskey....makes ya feeEEeel betta //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifmy bad im hyped up on dayquil right now and not thinkin strait
i been drinkin r&r w/ coke for a good little while now... //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gifHave some whiskey....makes ya feeEEeel betta //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
weak //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gifi been drinkin r&r w/ coke for a good little while now... //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
