right, im stuck between 4 brands, there..:
helix
Helix HXS 235 G - Helix 5.25" 2 Way Component System
5.25 inch woofer with 25 mm soft dome tweeter and 2-way crossover with integrated tweeter protection
Power RMS/ MAX: 50/ 70 Watt
Sensitivity: 90 dB 1W/1m
Frequency range: 70 Hz - 21 kHz
Impedance: 4 Ohm
Mounting depth: 58 mm
HXS235 G - Helix HXS-235 5.25" 2 Way Component System
Rainbow: SLX230 Deluxe - 13cm components
Product Features
DREAM LINE SLX RANGE
5.25" (130mm) 2-way component system.
component speaker system includes woofers, tweeters, and crossovers
Dream Line SLX specifications:
Silk Dome adjustable tweeter
tweeter level attentuation
Butyl-rubber surround of woofer
Vented aluminium voice coil former with spider
120W maxmimum power
80W RMS Power handling
Sensitivity:90db
Frequency response: 60 - 21.000 Hz
Crossover Frequency: 4.200 Hz
Mounting depth without / with ring: 54 / 52 mm
Diamond: D352 - 13cm component speakers
Product Features
5-1/4" Component System, with 1 inch Alloy Tweeter
Power Range (watts): 60W RMS /100W MAX
Impedance (ohms): 4
Sensitivity with w/2.83-V input @ 1 meter (dB SPL): 90
Freq,. Response 65Hz to 20kHz (±3dB)
Woofer Cone Material: Co-Polymer
Tweeter Cone Material: Aluminum
Mounting Type: Flush, Angle
Mount Depth Largest Driver: 1-5/8"
Diameter Largest Driver: 5-1/4"
Crossover Included
Priced per pair
CDT audio, not sure what make/model they are, as i seen them in my local car audio shop at £180.
thanks in advanced, im sooo confused.
im takeing a likeing to the rainbow, but just seeking advice beforehand.
what ever brand i get ill also be getting the simular spec from the same brand in coaxal, just for rear car sound fill.
thanks again.
helix
Impedance: 4 Ohm
Product Features
120W maxmimum power
Sensitivity:90db
Product Features
Impedance (ohms): 4
Crossover Included
Priced per pair
thanks again.
