62caddy
There are so many options out there as far as subwoofers go...I have given up on Orion HCCA subs because of all the people that said how crappy they are. My newest interest is (2) RE Audio's XXX 15" woofer. I found some dual 2 ohm subs on eBay for around $635 (each) shipped. I figured I could run these on a couple of cranked up Rockford Fosgate T10001BD at 1 ohm. I would like any honest opinions on these subs. They will be going into my '62 Coupe DeVille. Ohhhh also what would you suggest as far as a box goes (sealed, slotted, ported, blow-thru back seat...). I want quality as well as loud here.
Here are some specs that were on the eBay listing:
* 15" XXX-Series Subwoofer
* 2000 Watts RMS
* Dual 2 Ohm
* Dual Composite 2-Piece Cone
* Rubber Surround
* Integrated Gasket
* Cast Aluminium Basket
* Tork-Tite Terminals
* 3" 4-Layer Flatwind Aluminium Voice Coils
* Split Coil Design
* VMS Vented Magnet System
* Dual Progressive Spiders
* Integrated Tinsel Leads
* Electrical Q Value -Qes: 0.58
* Mechanical Q Value -Qms: 3.62
* Total Speaker Q Value -Qts: 0.501
* Free Air Resonance -Fs: 19.10 Hz
* Equivalent Compliance -Vas: 207.0 liters
* One-Way, Linear Excursion -Xmax: 54 mm
* Efficiency -SPL 1W/1m: 85.81 dB SPL
* Effective Piston Area -Sd: 810 cm^2
* DC Resistance -Re: 4.2 ohm
* Nominal Impedance -Znom: Dual 2 ohm
* Thermal Power Handling -Pe: 2000 W
* Force Factor -Bl: 18.16
THANKS!
-Rick
* 2000 Watts RMS
* Dual 2 Ohm
* Rubber Surround
* Integrated Gasket
* Split Coil Design
THANKS!
-Rick
