Well I am considering this amplifier since my JL 500/1 broke just recently.
This amp will be powering my 2 JL 12w3v2-4 subwoofers.
I like the features of this amp. Mainly because its all digital and is fairly powerful if I want to later down the road upgrade subs.
Link:
RE Audio XT1600.2V3 2-Channel Class "DE" Digital Stereo Amplifier
Here is the info on this amp:
RE Audio XT-1600.2V3
I also like the price.
And that is shipped.
Link:
RE Audio XT Amplifier Series
Working in a successful car audio system requires careful planning and quality components. Working in more affordable pricing for high quality product is easier now more than ever with RE Audio’s introduction of the XT Series of amplifiers. The entire line is crafted with precision from the ground up, beginning with the perfectly symmetrical circuit boards – RE Audio designs these with pride showcasing their cleanliness from the circuitry up.
An elevated efficiency platform makes these amplifiers drain less strain on your vehicles charging system to allow for more power output with less draw from your vehicles battery and alternator. Great power output in an affordable package with clean power output is what’s desired from every amplifier on the market, and the RE Audio XT Series of amplifiers provides this with their Multi-Channel and Monoblock lineups.
Offering specific models for 2-Channel, 4-Channel, and Monoblock applications RE Audio has provided a plethora of options to use their amplifiers in, be it an entry level system to a high end competition system. XT Series Amplifiers provide some of the best available value, and don’t cut back on their quality – an amplifier that truly defines quality meeting value.
* XT V3 Series 2-Channel Class DE Car Amplifier
* RMS Power Rating:
o 4 ohms: 250 watts x 2 chan.
o 2 ohms: 500 watts x 2 chan.
o Bridged, 4 ohms: 1000 watts x 1 chan.
* Dynamic (Max) power output: 2000 watts
* High speed digital stereo amplifier
* Elevated Efficiency Platform guarantees the abundance of power, without a heavy drain on the vehicles charging system
* Remote bass level input (remote level control sold separately)
* Pulse Width Modulated MOSFET power supply
* LED power (green) and protect (red) indicators
* Variable Bass Boost (0 to +12 dB bass boost at 45 Hz)
* Screw terminal barrier strip speaker connector accepts 8-18 AWG speaker wire
* Soft start turn-on technology
* 2/1 channel operation
* 1 RCA Pair of preamp RCA outputs to daisy chain multiple amps
* 3-Way System Protection circuitry (thermal, overload, and speaker short protection)
* Heavy duty aluminum alloy heatsink for excellent heat dissipation
* Convention cooling system
* Nickel-plated RCA level inputs
* Nickel-plated screw terminals
* Maximum Input Signal: 6V
* Low level input sensitivity: 200mV to 8V
* Fully adjustable butterworth high and low pass crossover filters
* Variable high-pass filter (40-1,000 Hz, 12 dB/octave)
* Variable low-pass filter (40-250 Hz, 24 dB/octave)
* Subsonic filter (15-40 Hz, 24 dB/octave)
* Average Efficiency:
o 4 ohms: 70%
o 2 ohms: 65%
* Signal-to-Noise Ratio: 110 dB
* Frequency response: 5-50,000 Hz
* Dimensions: 14-1/2"L x 10"W x 1-7/8"H
* 1/0-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
* Also Found As: RE Audio, US Amps, XT16002V3, XT-16002V3, XT1600 2V3, XT-1600.2V2
- List:$339
- Sell price:$169
- Sell price + coupon code(re20march):$136
