RE Audio SX VS XXX
the XXX has the advantage way down low
the SX has the advantage past 50hz at any level. The SX will be louder than the XXX in nearly EVERY application.
How do you conclude the SX will be louder in nearly every application? Obviously, even by your own words, they would not be louder in a system running the subs up to 50hz or so. Dont even bother mentioning above 80hz, XXX's **** above that, but subs shouldn't really play higher than that anyway.
XXX has almost 50% more displacement potential than does the SX, along with more power handling. I would love to see a test showing the SX being louder than the XXX "in nearly EVERY application". Im calling BS on this one.
if someone gets a XXX they get it off hype.
That's a funny statement, coming from the king of the Type R hype. There are plenty of good reasons to buy a XXX, none of which is merely 'hype'. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
the XXX is very very ineffeciant... the SX is moderate to high effeciancy.
Thats what makes the SX louder in nearly every application, at *any* note. High power EXTREMELY low tunes is the absolute only time the XXX is worth a look, I'm talking where you need output below 28hz... Thats all. Beyond that, the SX will be louder than the XXX 99% of the time. The XXX is an SQ woof, SX is a daily beater woof...
Fine.. the XXX has much more displacement... but what power does it take to get it? Will it go thermal before you get to that point? Answers: *alot*, and YES thermal will happen before xmax in the typical application. There goes that wonderful displacement...
Also... we all know displacement plays little to no factor in a ported box....
WHy get a XXX when you can get a woof that costs less and does more? Because its big and shiny? Because people say its great? Thats hype, and thats why people buy it. Extremely few will use it for what its truly best at, lots of output into the absolute lowest octaves... below what is useful in most any music.
Its funny you say the XXX's efficiency is so bad, and the SX is 'moderate to high', yet even in David's test the SX only peaked about a db higher than the XXX (approx the same diff as from the SX to the MT). So I guess this makes this MT super super super efficient iyo? Efficiency is not the only name of the game in output, Im surprised to hear you speak like it is. One sub can be more efficient thereby having more output at a given input power level, but that does not mean its 'always' louder. The XXX has more power handling potential than the SX (which IS a benefit in ported applications), not just more displacement. The only real advantage Ive seen in output from the SX to the XXX is in the SX peaking higher, making it easier to burp those tones at your car's resonant freq. Beyond that, in my experience (have owrked with both drivers), the XXX gets louder. Sider by side, the XXX gets -clearly- louder playing music. I guess the applications Ive been around all fell into that 1% category?
Id love to se you prove an SX will always be louder (or 99% of the time) above 28hz (given similar installs).
Your xmax statements are waaaaay too general. Lets break them down. You said the XXX has more displacement, but how much power will it take and will it 'go thermal' before reaching its xmax. There's some interesting assumptions and key information left out of those examples though, right? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Such as, what box type are we speaking about. If its sealed, you cannot dismiss xmax figures so easily. Frankly sealed, XXXX simply owns an SX (according to specs, my ears, friends' ears, etc etc). Ported the SX does not have such a huge disadvantage, because as you stated, displacement potential doesn't mean -as much- ported. I wont agree displacement plays 'little to no role' in ported applications, as that's a statement only an SPL guy would make. If you are burping your vented system at or near tuning, for an SPL burp, yes displacement (xmax) means little to nothing, as thermal limits come into play. But your logic and reasoning ended there (and did not bother explaining that little detail). Change the situation a little bit, we are still using a ported system, but we are now playing music (what the XXX was designed for) instead of a single note burp near tuning. Now displacement starts playing a bigger and bigger role. The more you deviate from tuning in a vented system, the more con excursion comes into play. Cone excursion means little to nothing for SPL burps, but playing music is another story. Why'd you leave this out of your reasoning?
As for the thermal issue (you say a xxx WILL go thermal before reaching xmax... hence your 'there goes that wonderful displacement' comment), its strikingly biased against the XXX also. I notice you dont mention (again) that you are obviously only referring to an SPL burp type situation when you say the XXX will go thermal before reaching its xmax (not to mention just about every other speaker on the planet... reaching xmax at tuning is extremly difficult). Or, are you trying to convince us you cannot reach full excursion potential with a XXX without it melting down 'in every circumstance'? No, of course you aren't, but I do find it interesting you skew all your examples to favor the SX and slight the XXX. Why is that?
Lastly, your statement than an SX 'does more' for less money is absurb. Again, only a comment an SPL head would make. If peaking louder is the only thing that interests you about a subwoofer, yes I can see where you'd say the SX 'does more' for less money and buying a XXX is merely for the hype. But when you start looking at it with something other than your tunnel vision (only setting up situations advantageous for SX and disadvantageous for the XXX), its clear the XXX holds many advantages over the SX. I would take a XXX over an SX for daily listening (music) 100 times out of 100. You wouldn't? Right. Clearly you are biasing your responses towards SPL, but you word them as if they apply to all situations. Your posts are very misleading in this regard.
As for the thermal issue (you say a xxx WILL go thermal before reaching xmax... hence your 'there goes that wonderful displacement' comment), its strikingly biased against the XX also. I notice you dont mention (again) that you are obviously only referring to an SPL burp type situation when you say the XXX will go thermal before reaching its xmax (not to mention just about every other speaker on the planet... reaching xmax at tuning is extremly difficult). Or, are you trying to convince us you cannot reach full excursion potential with a XXX without it melting down 'in every circumstance'? Bo, of course you aren't, but I do find it interesting you skew all your examples to favor the SX and slight the XXX. Why is that?
Lastly, your statement than an SX 'does more' for less money is absurb. Again, only a comment an SPL head would make. If peaking louder is the only thing that interests you about a subwoofer, yes I can see where you'd say the SX 'does more' for less money and buying a XXX is merely for the hype. But when you start looking at it with something other than your tunnel vision (only setting up situations advantageous for SX and disadvantageous for the XXX), its clear the XXX holds many advantages over the SX. Clearly you are biasing your responses towards SPL, but you word them as if they apply to all situations. Your posts are very misleading in this regard.
The XXX is going to average lower SPL numbers over the range... perhaps that will appear louder? Yea, the SX WILL be more peaky, and it probably will peak at a higher note in the *same* box. Are we talking about the same box here? no... we are talking about both woofs being in optimal enclosures.
The SX is going to need a larger box to effeciantly tune low... but it does effeciantly tune low if you know what your doing.
Sorry if I sound too objective to ya... but the meter doesn't lie //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. In a direct swap, the XXX may appear louder because it will be at a lower note, but that doesn't mean the SX can't be made to achieve higher SPL at that lower note in a different box.
Agreed on the XXX spanking the SX sealed... the SX is a crappy sealed woof, on top of displacement being a bigger factor sealed. I've never thrown big power at a sealed XXX or SX, but displacement is king sealed, and the XXX sure as hell sounds better sealed.
"Appearing" louder and BEING louder are 2 different things. Enjoying the sound of the XXX more than the SX is one thing.. saying its "louder" without a meter just isn't gonna work.
I understand where you are coming from, but imo you are trying to define 'louder' too rigidly. One may peak louder on a meter (IF the install is designed too.. daily SX installs lack something imo), but the other will play louder -on average- across the frequency spectrum a subwoofer is expected to play. Some poeple call it 'louder to the ear' or 'appears louder'... whatever. Point is SPL is a measurement of pressure (as you know //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif), and more displacement = more pressure build up (simple physics). Sure, stack the deck by putting them in a situation where the XXX's displacement advantage is the least (vented system playing very near tuning) and the SX's efficiency advantage is at its biggest, and it will appear the XXX doesn't justify its cost increase. But put them in just about any other situation (sealed for SPL or music, vented for music, etc) and the XXX will simply outperform the SX is virtually every category (except above 80hz //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif).
Peakin around tuning, nah... the SX peaks much above tuning. Its difficult to get an effeciant low tune while still sounding good, but it can be done. Perhaps you just havent heard a properly setup SX?
The XXX has its uses, but IMO its just a waste of $. If you enjoy the sound of it so much more, I suppose thats your preference.
The SX peaks much above tuning? What does that even mean? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Tuning of what enclosure, for what vehicle, for what purpose?
Ive heard an SX sealed (unfortunately //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif), Ive heard an SX in a low tuned vented box (30-32hz) and Ive heard multiple SX setups with high tuning (40-60hz Id assume). Im not saying the SX sounded 'bad', but against the XXX in a low tuned box for music, they just ... lack something (besides low end) imo. *shrug*
We're an RE Dealer. We install ALOT of XXX's and SX's on a weekly basis. In "our" (Superior Sound's) opinion. The XXX out performs the SX in all category's besides a burp on the mic in an SPL enclosure.
Now, that's with the old XXX.
The new XXX is twice as loud in the frequency range of 20-45Hz than an SX. Hell the new XXX absolutely destroys the old XXX in the low, low range. 20-35Hz.
How would I know? I was the first person in the US to have the new XXX in a vehicle. 5 weeks and counting. 6 different enclosures.
AudioFanatic
AudioFanatic
Nati
fakename
