re 8'' s with rf 160a2...help please
rustycar
hello, i have a pair of re8"s in a seprate sealed .35 enclosures, i have two rockford old style punch g160a2 amps. there are behind the seat of a normal cab 88' chevy s-10.
whats the best wireing for this combo?
175w on the re8" (is this rms?)
using two amps:
if i wire each both coils (of each sub) to both channels (of each amp), ill be getting 80w @ 4 ohm per channel, (is it safe to run each coil to left n right?)
using one amp:
if i wire both coils (of each sub) to one channel, both coils of other sub to other channel, ill be geting 80w @2ohm. (this will allow me to sll other amp)
or...
wire both subs to obtain 4ohm load and wire to bridged at 160 @4ohm,,,,,,,,80w each
the way i wrote that is a bit confusing but thats why iam here asking the pros...i hope u get me....
can i link both amps togather? and get more watts for this set up?
if the only possiblity is 80w to each sub, what can i expect out of these 8's? half power? 3/4 power?....
thank you much for any help,,,,,
here are the specs,,,,
RE SERIES
T/S Parameters8”
Electrical Q Value -Qes: 0.38
Mechanical Q Value -Qms: 4.21
Total Speaker Q Value -Qts: 0.34
Free Air Resonance -Fs: 22.8 Hz
Equivalent Compliance -Vas: 27.1 liters
One-Way, Linear Excursion -Xmax: 12 mm
Efficiency -SPL 1W/1m: 81.2 dB SPL
Effective Piston Area -Sd: 195 cm^2
DC Resistance -Re: 3.2 ohm
Nominal Impedance -Znom: Dual 4 ohm
Thermal Power Handling -Pe: 175 W
Force Factor -Bl: 15.4
RE SERIES
Product Dimension8”
Mounting Depth - 4”
Mounting Hole Diameter - 7.125”
Overall Diameter - 8.25”
Bolt Hole Circle - 7.75”
Motor Width - 4.875”
Motor Depth - 1.5”
Basket Depth - 2.5”
Displacement - 0.07 cu. ft.
Weight - 6 lbs.
Specs per Manual:
Dynamic Power rating (IHF-202 Standard)
mono into 4ohm load - 236Wx1
per ch into a 2ohm load - 113Wx2
per ch into a 4ohm load - 77Wx2
RMS ratings
per ch into 4ohm load - 40Wx2
per ch into 2ohm load - 80Wx2
mono into 4ohm load -160Wx1
Signal-to-Noise Ratio - >100dB A-weighted
Crossover Slope (Butterworth) - 12dB/octave
Crossover Frequency - 80Hz
IM Distortion (IHF) -
rustycar
rustycar
harrisville
rustycar
