SOLD RD audio D5 amp 600+half of shiping
woodels420
the man
i have a rd D5 that is in perfect shape.i want 600
+ half of shipping.i will split shipping cost.i have gotten riped off on here 3times so when the money is in my paypal account i will transfer it to my bank when it clears i will ship the same day.this is how my deal with pionerrpimp went when i bought my mach5spl.need money to move being kicked out of the inlaws house.
this can run at .25ohm if u have the elctrical to back it up.RMS power, 2 ohm linkable/dual mono 5600w x 1ch
RMS power, 0.875 ohm mono 3750w x1ch
RMS power, 1 ohm mono 3000w x1ch
RMS power, 2 ohm mono 1500w x1ch
RMS power, 4 ohm mono 750w x1ch
Signal to Noise Ratio >100dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 300A(external type fuse - not included)
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 222(W) x 52(H) x 590(L)mm
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
The 750 will give you better control at higher volumes as you won't be reaching clipping as soon..
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
woodels420
the man
woodels420
cullman,al
xxBAFOWxx
