RD Audio Ampliier Goodness! 1, 2, & 4 Channel Amps!
ewoevo
RD Audio 100.4
RD Audio 1000.1D
RD Audio 160.2
100.4: 4 channel amp, only used for 3 months, 9/10, works perfectly no visible issues
1000.1D: mono class D amp, NIB, never used, just removed from wrapper for pics
160.2: 2 channel amp, prototype never produced, used for 3 months, 9/10, works perfectly no visible issues
100.4: $300 shipped
1000.1D: $300 shipped
160.2: $250 shipped
See price
View attachment 26543444View attachment 26543445View attachment 26543446View attachment 26543447
Here are specs for the 100.4 and 10001D amps:
RD Audio 100.4
* Class AB 4ch Amplifier
* Dual MOS-FET power supplies
* Stereo RMS power---100w x 4 @ 4 ohms @14.4V
* Stereo RMS power---125w x 4 @ 2 ohms @14.4V
* Mono RMS power---250w x 2 @ 4 ohms @14.4V
* Input mode 2ch/4ch
* Frequency Response 20hz - 20khz
* X-over HPF/Full/LP-BP
* Continuously variable @12db/oct
* High Pass Filter 50hz - 5khz
* Low Pass Filter 5khz - 50hz
* Band Pass Filter 50hz - 5khz
* Signal-to-noise ratio 105db
* Input sensitivity: 200mV-6V
* 3 way protection: over voltage, speaker short & thermal overload
* Total harmonic distortion:
* Continuously variable 0 – 18dB Bass Boost
* Power Consumption
* Working Voltage 11-15Volts
RD Audio 1000.1
* Digital mono block amplifier
* Efficiency over 86%
* RMS power handling---300w @ 4 ohms @14.4V
* RMS power handling---600w @ 2 ohms @14.4V
* RMS power handling---1100w @ 1 ohms @14.4V
* RMS power handling---1400w @ .75 ohms @14.4V
* Signal-to-noise ratio 100dB
* Phase shift 0-180 degree
* subsonic filter: 10-50Hz
* lowpass filter: 35-250Hz
* Continuously variable 0-18dB Bass Boost
* Built-in variable 24dB per octave x'over
* Power Consumption
* Working Voltage 10-16Volts
would love the 4 channel t go with my 1750 , any trades , if so ,what you need ?
Not really looking for trades. I'm moving to Mosconi amps and processor. I already have PHD comps and iD subs, so I'm set there as well. If I think of something, though, I'll let you know.
38
The siq amps are Sq beast as well. And much cheaper. Made by s&I in Korea iirc
296
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
528
ewoevo
ewoevo
FL Panhandle
aztec
    May 16, 2024
    May 16, 2024
