RD Audio Ampliier Goodness! 1, 2, & 4 Channel Amps!
ewoevo
RD Audio 100.4
RD Audio 1000.1D
RD Audio 160.2
100.4: 4 channel amp, only used for 3 months, 9/10, works perfectly no visible issues
1000.1D: mono class D amp, NIB, never used, just removed from wrapper for pics
160.2: 2 channel amp, prototype never produced, used for 3 months, 9/10, works perfectly no visible issues
100.4: $300 shipped
1000.1D: $300 shipped
160.2: $250 shipped
See price
View attachment 26543444View attachment 26543445View attachment 26543446View attachment 26543447
Here are specs for the 100.4 and 10001D amps:
RD Audio 100.4
* Class AB 4ch Amplifier
* Dual MOS-FET power supplies
* Stereo RMS power---100w x 4 @ 4 ohms @14.4V
* Stereo RMS power---125w x 4 @ 2 ohms @14.4V
* Mono RMS power---250w x 2 @ 4 ohms @14.4V
* Input mode 2ch/4ch
* Frequency Response 20hz - 20khz
* X-over HPF/Full/LP-BP
* Continuously variable @12db/oct
* High Pass Filter 50hz - 5khz
* Low Pass Filter 5khz - 50hz
* Band Pass Filter 50hz - 5khz
* Signal-to-noise ratio 105db
* Input sensitivity: 200mV-6V
* 3 way protection: over voltage, speaker short & thermal overload
* Total harmonic distortion:
* Continuously variable 0 – 18dB Bass Boost
* Power Consumption
* Working Voltage 11-15Volts
RD Audio 1000.1
* Digital mono block amplifier
* Efficiency over 86%
* RMS power handling---300w @ 4 ohms @14.4V
* RMS power handling---600w @ 2 ohms @14.4V
* RMS power handling---1100w @ 1 ohms @14.4V
* RMS power handling---1400w @ .75 ohms @14.4V
* Signal-to-noise ratio 100dB
* Phase shift 0-180 degree
* subsonic filter: 10-50Hz
* lowpass filter: 35-250Hz
* Continuously variable 0-18dB Bass Boost
* Built-in variable 24dB per octave x'over
* Power Consumption
* Working Voltage 10-16Volts
would love the 4 channel t go with my 1750 , any trades , if so ,what you need ?
Not really looking for trades. I'm moving to Mosconi amps and processor. I already have PHD comps and iD subs, so I'm set there as well. If I think of something, though, I'll let you know.
These have been used for a few months and then were pulled for pro drivers to take their place for more output. These are 4 ohm drivers and in...
38
992
The siq amps are Sq beast as well. And much cheaper. Made by s&I in Korea iirc
280
ewoevo
ewoevo
FL Panhandle
aztec
    May 16, 2024
    May 16, 2024
