RCAs going bad or ground??
bear metal
Well there's your problem, the fur is getting in the way of the ground. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Let's see..... you have accessory noise so it will be in the head unit. Did you use a factory ground or a fresh new ground when you grounded the head unit? Most accessory noise is a result of an improperly grounded head unit. If you did use the factory ground wire it's 99% likely the cause of the acc noise.
Even if you didn't - reground the head unit on a nice fresh piece of metal and try again. This is a signal path noise, don't bother with the amp. It's at the head unit.
SQfreak06
SQfreak06
West Palm Beach, FL
o. l. t.
