RCA Cables
  • 2
No make or model number on it? Do you have an exact picture of the rear and all its glory?
8
686
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
677
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
596
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
6
756
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
11
905
BZkid14
BZkid14
Antioch IL
chris229
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
