RCA Cable Ports on amp??
Both or just one, cus one says output and headunit has 2 outputs
You can use a y-splitter so you can use both rca sub outs from your HU to the one on your amp. You'll get a higher voltage signal going to the amp. Not really necessary though.
subbass is mono and I don't think you gain voltage by using both or lose any by using one
No make or model number on it? Do you have an exact picture of the rear and all its glory?
851
It's really hard, almost impossible to induct noise into RCAs. All you need is a simple set of shielded RCAs. Some home audio guys once did a...
19
Yep, the subs don't move at all when both RCA cables are plugged in. I updated the firmware this morning. Unfortunately it didn't fix my issue...
33
7K
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
882
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
743
Reddish Neck
TD's & Beer
Reddish Neck
Racine, WI
dumple
