Rate My Set-up Please...
iLL Ridge
NC
I have a '98 Astro- big cabin.
I have kicker rs65's in doors and tweets in a pillars-powered by boss cx650 at 150watts/side or so.
Two lanzar otpidrive 12's 1000rms/pc dual 2 ohm coils.
I have a pg1200rsd at two ohms on the subs- prefab vented box-3.5cu ft or so.
rear battery- 4ga wiring, stock alt.
JVC headunit with 3 rca outputs, usb,para eq, x-over, etc. 4 volt pre outs.
System sounds good at volume 40/50. Any much louder and it fails. Max voltage on the 1200rsd- 75volts at the spkr terminals.
Max on the boss is 48volts bridged per side.
Boss is very over rated and wont have a clean signal.
The prefab box needs to go.
The system needs to be tuned properly. Your clipping your speakers and you will inevitably blow something very soon.
I would beg to differ. Matter of fact I'd bet money on it.
Boss is not clean power. Granted. Mids and highs sound good up to very loud. Amp runs out of steam.
Bass is pretty strong, but I don't like the tuning- need another box.
I am not new.
I can tune a walkman to knock.
I would beg to differ. Matter of fact I'd bet money on it.Boss is not clean power. Granted. Mids and highs sound good up to very loud. Amp runs out of steam.
I am not new.
I guess your just so great there was no need for this thread.
If you really weren't new, you might have known better than to buy half of that garbage..........................and might have enough sense to run a skill-saw, tard.
iLL Ridge
iLL Ridge
NC
slam
vegang
vegang
