Random Picture Thread
Who makes it? Engine displacement? How much HP?
Suzuki Boulevard M109R
Distributor American Suzuki Motor Comp.
Engine four-stroke v-twin, DOHC, four valves per cylinder
Displacement 1783cc
Bore x Stroke 112mm x 90.5mm
Fuel system fuel injection
Power 127 bhp @ 6,200 rpm
Cooling liquid cooled
Ignition digital transistorized
Transmission five-speed
Frame high-tensile steel
Front suspension 46mm inverted fork with 130mm (5.12in) of travel
Rear suspension link type single shock with 120mm (4.72in) of travel and spring pre-load adjustment
Rake/trail 31.1°/ 4.88in (124mm)
Brakes front/reartwin 310mm discs front with four piston calipers / 275mm disc rear with two piston caliper
Tires front/rear130/70-R18 / 240/40-R18
Dry weight 319kg (703lbs)
Wheelbase 1709mm (67.3in)
Seat height 706mm (27.8in)
Fuel capacity 5.2 gallons
Fuel consumption n/a
Colors black, white, red
Has anyone else tried these? This is my first time. It says cook for 4 min or longer for softer noodles. I found 8 min to be perfect. These are not bad. The flavor packet is liquid instead of powder. $9.99 for a pack of 4 at Target. I just wanted to try them because they are flat noodles and because the name struck me funny.
I want to go down and buy this so damn bad. I have talked myself partially out of it. Used and listed just under $10k
It's a nice bike, but that headlight is not desirable. It looks like it's melting off.
Suzuki is really starting to ramp up their bikes. For 2025, they revamped a lot of their big sellers. I was extremely surprised they maid the DRZ400 fuel injected. That was a huge improvement. I just wish they would do that to the DR650. If they do, I might buy one.
Slo_Ride
Regulator
Slo_Ride
ATLANTA
ThxOne
