Random Picture Thread
If you say so. Just make sure you replace both bearings and races, cause they will be trash, and hope didn't f*ck anything else up to bad. If you did like the moron in the pic and left the brakes on then you probably need to replace the rotors, the calipers, and completely flush and replace the brake fluid. I've literally had to dig out cars that where buried in the ground well above the frame and never once had to take more than a 1/2 ratchet to a spindle nut. You are going to argue with me no matter what, even though we both know you are full of shit so cool, whatever you say bro. ✌
You will argue about anything.
There have been some toyotas that I remember having to break the torch out for. You're appluing heat mainly to the nut on the axle shaft. If you get the nut off and knock the axle through the hub, there isn't much heat that gets transferred to the bearing.
Slo_Ride
Regulator
Slo_Ride
ATLANTA
ThxOne
vegang
vegang
