Raising voltage
Bobby322
I have a stock battery with a c&d battery in the back. I have a 1/0 run from the front battery positive to the back battery and 1/0 for the rest of connections for back battery. I want to try to increase my voltage and have less drops so whats the best way to do that? Other than doing the big 3, what should I do? A new battery under hood? another back battery? I dont have a volt meter so idk how low my voltage drops are going. I want to be at around 13v even on heavy bass hits.
also, is it bad to mix battery brands? as in, is it bad if I wire my c&d battery in the back with a different battery?
MLA and 2 reserve batteries. And it will still probably dip into the 12s, depending on the amount of playing time between fully charging because your OEM alt isn't really designed to keep up with the current draw of a 3000w amp.
well im prob. going to sell the ap30001d and I want something like an AQ2200. So what do I need to keep my voltage up?
'04 dodge ram 1500 work truck 4.8 v8. stock battery is prob. as old as the truck. c&d i got during the summer. Ill prob go to to walmart and get one.
yeah i probally will get another c&d battery.
I have a dmm, but its not very useful with checking voltage drops. what type shoud i be looking to buy today?
its a 4.7 my bad.
you cant raise voltage you unless you get 16 volt batteries and an externally regulated alternator
how ever you can prevent voltage drop.
voltage drop is a product of resistance if you have 1 run of wire a factory alt and 2 dissimilar batts your on the right track for voltage drop
first step is to replace factory battery dissimilar battery's do what's called parasitic discharge, that means that they discharge into each other trying to achieve equilibrium and will continue until they die
second step is to do a wire upgrade for your alt and grounds (big 3) i know you dont want to but its the only option do it or have votage drop no way around it
if you plan on doing more runs of 1/0 the next one should be a ground from front battery to back battery
and from that point on do equal number of runs per + and - terminals having a bunch of +++++ and only 1 - is going to make voltage drop too
then like all the other guys do more batteries in the back
if you plan on using a 2-3kw amp just do the math on how long you can sustain the voltage
look here
http://www.gizmology.net/batteries.htm
plus if you have a 2kw amp and a 150 amp alterntor when your amp is being used to full power you will get somewhere around 2100 watts
150*14=2100
so if your not using anything except the ignition you should bet very little time before you get drop
but you have a radio dashlights ignition computers headlights whatever
with your battery you should get about 45 min until its dead at full tilt but music is dynamic so double that time 1.5 hours best guess
now add a second battery and a 250 amp alt
250*14=3500 watts
136*2= 272ah
1.4 hours of battery life and now you got 1500 watts to pump back in to the battery but eventually your alternator will saturate with heat and not keep that up
this is all perfect conditions and with no voltage drop over your cables
if your batterys are less than 1 foot from your amp your good if not you need more wire
any meter will show voltage drop digital 3$ or 20 year old analog all the same , put the meter in the wire right at the terminal of the amp and play the system what is the lowest number you see ?
now turn stereo off and put it at the front battery and rev the engine a bit what is the highest number you see ?
subtract the 2 that is your voltage drop with the alternator on
now turn the car off and do it again same place amp at full tilt and front battery that is voltage drop without the alternator
long story short you need power to make power
Bobby322
Bobby322
TX
psychoacoustics
