radio install
I'm not sure about wiring a deck without factory wiring, but I'd assume a power wire from the deck to the + terminal on your battery, and the ground wire to some bare metal, just like installing an amp... you'll need both cables the same gauge, and your fuse will be on your power wire, as close as possible (no more than 18" from the battery).
Good luck...
I'm not really sure how a deck connected to factory wiring overcomes this problem... I couldn't really tell you. =) Never really seen someone try to put a system in a vehicle that never had even a radio in it. =)
Originally posted by bronco2323 ya thats some hard ****
Not really...
Just find an empty terminal in your fuse box that turns on and off with the ignition. If you can't find one you can tap into something else that powers up with the ignition. If you still can't, then connect it to your battery with a switch. Your yellow will be your constant power wire, the red your "switched" (or ignition) wire, and the black is your ground.
Probably the adapter brand. Other users have found that the pins do not coincide with the factory pinout guide. They have solved this by pulling...
That blue wire with the "remote control" sticker on it: It's NOT a remote control wire. Its a remote... control wire. Its a switch that...
bronco2323
bronco2323
house
bronco2323
    May 12, 2024
Brendon Jenness
    May 11, 2024
